Where's the best place to source bits from to make up my throttle & clutch cables ? (Indy carb'd R1) Most of the usual suppliers seem a bit thin on the ground when it comes to this stuff.
For throttle cable you can use Bicycle brake cable. I just used a universal one from my local bike shop.
For clutch cable I got one made up by Venhill Engineering in Dorking.
Contact Details:-
Venhill Engineering Ltd
21 Ranmore Rd
Dorking
Surrey
RH4 1HE
Tel:-01306 885111
I actually redesigned the normal setup so that the cable outer moves rather than the inner
pic here
by using an adaptor that my local machine shop knocked up for a fiver out of stainless.
pic here
The advantage is that my cable is only approx 18" and straight from the pedal rather than the usual big loop.
- Jim
[Edited on 28/3/07 by jimgiblett]
throttle kit from a company called zoom karts
cable 99p push bike one from wilko
get a spare nipple from the go kart place aswell
For clutch I just used a cut down Mk2 Escort cable. Ive done similar to Jim but as I had a bit of lower engine cradle nearby I just put a mount on
that and turned the clutch lever around (its on splines) so it pulled towards the drivers footwell.
Picture / thousand words etc, so have a look at Rich Miles's website here, as
Rich did it in a similar way.
cheers!
