Could some one please fill in the ? on my dreadful sketch. It is of the front face of a type 9 box I need to know the bolt spacing measurements for
the bellhousing.
I have done a search, found some great drawings but not of this.
Thanks.
Steve.
I can email you this for A4 paper if you need it as a template in jpg format, the dots I have put on are about 2mm so you can use as a drilling
template. The dimensions are as follows.
top width 13.4cm
bottom width 14.2
drive shaft is 4cm below centre of top width.
Sorry I deleted the other post I resized the image.
Glad to hear that there will be another K in the fold!! I am looking at getting mine mounted in the chassis in the next couple of weeks.
I've got a cast iron bellhousing you can have if you like?
Thanks for the picture and the offer,
I have to go with the Getrag housing because of the crank sensor. It uses a hall effect trigger rather than the inductive type,
Thanks again.
Steve.
