Going make the engine mounts.
The ones that are alrteady on the chassis are poly bushed arms headeing in the general direction on the block fixing points.
Does the engine need to be mounted on rubber mountings, or is it ok with just the poly bushes.
Poly bushes are fine.
Regards Mark
I`m using poly bushes, the amout the egine moves is tiny.
cannot move the eingine if i rock the intake manifold.
My vectra i could rock loads with one hand!
