MT75 or TYPE9
markf - 25/4/07 at 09:23 PM
hi all,
can anyone tell what the difference between the two, and how it would affect the build
cheers
mark
RazMan - 25/4/07 at 09:28 PM
Not sure about the physical differences but the MT75 is a much stronger box - good for around 400 bhp iirc.
markf - 25/4/07 at 09:31 PM
cheers razman,
so it dont affect the build in any way then
mark
big_wasa - 25/4/07 at 09:38 PM
Oh yes it will
The box is slightly bigger.
What engine are you using ?
The Mt75 will handle more grunt.
To get mine in a bookish chassis I moved and changed a few bits.
UncleFista - 25/4/07 at 09:39 PM
If you're building to the Champion book then the MT75 might not fit, it's wider so you'll need to lose some room in the footwells.
It's stronger.
Has a integral bellhousing.
It's aluminium cased (lighter ?)
I'm not sure (someone who knows will correct me) but I think the box needs a different type of prop too, the box doesn't have a sliding input like the type9.
markf - 25/4/07 at 09:42 PM
well the car im looking at is a 1991 2L twin cam but dont know what box its got on it
gazza285 - 25/4/07 at 09:44 PM
MT75
markf - 25/4/07 at 09:46 PM
so thats good then?
zetec - 26/4/07 at 05:10 AM
I've got an MT75. The only real down side is that you will be stuck with the ratios it comes with, not a problem for my set up, but if you wanted to change to a close ratio or higher first gear ratio then you will need a type 9 and a few hundred £.
What engine are you using?
