how tall is a x-flow?
Cousin Cleotis - 3/8/03 at 07:10 PM
i need to know how tall a x-flow is from the bottom of the sump to the top of the rocker cover/filler cap.
i am thinking of using an engine and box out of a suzuki sj or carry(little van).
the carry's engine is on a slant which will make it not as tall as the sj's engine but could this cause any problems?
Thanks, Paul
Cousin Cleotis - 5/8/03 at 07:29 PM
is there nobody that knows how tall a xflow is or want to measure thiers?
i have searched the forum and with google but found nothing.
Thanks, Paul
Sideways 2 Victory - 5/8/03 at 09:35 PM
Paul, I'll measure mine (Phnar!) for ya tommorrow
Got a shortened sump and a different rocker cover to standard which has a much shallower cap.
Both factors mean the block + head figure is the only thing that will b of use to you.
Dave
david walker - 5/8/03 at 09:37 PM
Try searching again - "Engine Heights".
I posted a list of engine heights on here some time ago.
However to answer your question - from c'line of the crank to top of rocker cover (not including filler neck) a 1300 is 13.5" tall and a 1600 is 15" tall.
