Hi,
i am hoping to fit my engine this weekend so am filling the gearbox first.
I have the later style manual box which is meant to have atf type "g". I cant find this spec oil, will any atf do?
What have you used?
thanks
kenton
ah count yourself lucky for remembering, I forgot to do mine. I think the Castrol TQF stuff has been recommended for these. Not sure tho.
Any auto fluid is good to go, you cannot fill with hypoid as the box has a small pump in it.
If you want to improve the change get some synthetic gearbox oil.
They change the recommened oil serveral time s but any normal ATF will do --- ie non Dextron.
Thank you,
off to halfords then into the workshop!
