Finally put Zetec in. Clutch and release bearing are Sierra, as supplied by Tiger. Spigot bearing fitted.
tried to push clutch forward to test it. Arm wobbles a bit, but it's stuck.
Any ideas? Or am I just not pushing hard enough?
You won't push it by hand. Try using a lever as the spring tension is very strong.
Bear in mind how hard it is to push the clutch with your foot!!
[Edited on 12/5/07 by TangoMan]
Good, that's what I thought
