Anyone know what size socket fits the sprocket nut on an R1 engine?
I need to buy one!
Can't help with the size but can you get in to measure it with a pair of verniers? May help?
I'll be going in the garage in a minute, but I won't be returning for several hours!!!!!
Will do with the vernier.
Looks like a 36mm across the flats, 6pt.
Went to halfrauds and it was the only one missing from their range....typical!
I only need to get the nut off as my reverse cog goes in it's place.
Even my adjustable wrench won't open that far.
I will take a look in my firms tools tonight.
I'm also after a narrow 17mm socket for the bolts on my chain diff. They are countersunk and a normal 17mm is just too thick walled.
Loan mine if you pay the postage
370 grams parcel post or a fiver with trade card at halfords
[Edited on 28-5-07 by mangogrooveworkshop]
mangogrooveworkshop cheers for the offer. I will take a look at work first.
Martin
36mm is pretty standard size on modern bikes hence halfords never have them as just about every set you buy stops at 32mm so you have to buy that one extra one.
I managed to get a 36mm ring spanner for the sprocket nut.
I will take a look at plug spanners.
Cheers Guys
