Hi, I am in need of a bellhousing to go between my type 9 and xflow, but realise i am more likely to find one off a type 9 in a sierra.
So my question is will this fit a xflow?
Theo
Yes it will fit. Most 4 cylinder ford blocks are the same bolt pattern. Exceptions are the newer duratecs and zetec se blocks.
excellent, thanks very much.
my next question then is which sierra's used a type 9, rather han the MT75?
Cheers again,
Theo
Cheers again,
Theo
yeah i have a dohc with MT75 already and the bellhousings is a part of the casing and non removeable, but i have a book chassis so am now going to use
a xflow and type9, which i have, just need the bellhousing now to put them together
will give my local breakers a call
Mt75 is a much stronger box than the Type 9 ...if you can get it to fit, I'd use that.
There are also type 9s out there with an integral pig iron bell housing.
I'm not suggesting for a second that you would want one, but they do exist.
Got a cast iron bell housing you can have if you get stuck although postage may be a bit high
Cheers again,
Theo
Try to get hold of an RS2000 bellhousing (or buy new from Rally Design). The weight saving over the cast iron lump is very significant.
