ok, the tank in my velocity ( 7 style ) is at the back with the fuel pump in the tank on the passenger side....
the inlet manifold is on the drivers side....
originally i had the fuel lines routed from the tank, round behind the drivers seat ( not literally! ) down the tranny tunnel on the drivers side and
up and out to the top bar...
however, the mt75 gearbox goes close to the fuel lines...
so i thought id see what it was like to go down the tranny tunnel on the passenger side, all the way to the end, then up and over the top of the
gearbox to the drivers side...
trouble is im not sure which is best.....
any thoughts????
Mine's not a Velocity, but the fuel line runs from tank down bottom inside left of trans tunnel to about level with front of seats, then goes up
and over transmission. Then to flexi to engine.
HTH
Simon
any other views?
