Mondeo diesel Clutch release
r1_pete - 25/7/07 at 09:07 AM
Anyone used the Mondeo Diesel radial clutch release bearing with an MT75? Looks like a neat solution to a hydraulic clutch if it can be spaced appropriately...
Pete.
coozer - 25/7/07 at 09:26 AM
Is it the same as the one in the X type jag? Same engine.
Got any pictures of it?
r1_pete - 25/7/07 at 11:21 AM
No I'm looking for a solution for the clutch, Zetec / MT75 in an MGB, and came across the radial setup in the diesel Mundo, could be easier than converting the pedal from hydro to cable if it will fit the gearbox input shaft support tube.
Hence, wondered if anyone on here had done it...
Cheers.
Pete.
