LT77 gearbox mounts on V8 - explanation required please.
Cheffy - 7/8/07 at 12:15 PM
Hi Guys,
Can someone confirm for me please........
In the photo below there is a 'main' gearbox mount at the very bottom centre rear of the the 'box, but there are also two rubber 'cotton reel' mounts slightly above on either side angled at about 45 degrees.
Question:- Am I right in thinking that the centre 'main' mount takes the bulk of the weight, while the cotton reel rubbers are to help locate the 'box laterally, and aid with bracing the engine and 'box from rocking too much during revving and cornering?
LT77 gearbox mounts
LT77 gearbox mounts
TIA,
Mart.
[Edited on 7/8/07 by Cheffy]
PS. Actually, just realised, I think the 'box in the pic is an R380, still similar setup though.
Mart.
v8kid - 7/8/07 at 02:03 PM
Err I never had the side ones on mine just the bottom one. Is it supposed to have all 3 or are they for different models
clementine - 7/8/07 at 02:46 PM
That looks like a photo of mine from http://www.vord.net/cars/mgb_mods/gearbox/gearbox_mountings.html It's been modified a bit to use MGB mountings and crossmember.
I've a feeling the gearbox came with just two round bubbin mounts on the side and nothing in the middle. It would be able to move sideways if it had a single central mount.
It's an R380. I recall the mount locations are a little different on the LT77.
robinj66 - 7/8/07 at 05:16 PM
I've just used the two side mounts for my LT77
robinj66 - 7/8/07 at 05:25 PM
This site shows the original idea
http://www.rimmerbros.co.uk/rimmer/rover/sd1/mountings
Paradoxia0 - 7/8/07 at 07:13 PM
My LT77 has 2 cotton reels on the bottom of it.
In the picture below you can see the 2 mounts I am using (and I have replaced both of those mounts!) and also the 2 45 degree ones you are talking about. THis is the standard Luego setup I believe.
Mark
[img][/img]
Cheffy - 8/8/07 at 08:54 AM
Hi,
Thanks for the responses Gents.
Clementine, sorry to hijack your photo.
Martin.
