Is fitting a hydralic clutch to the 4 speed Ford box fairly easy?
Is there a slave that can bolt to the gearbox and pull the clutch lever?
And what would the master be from?
Anyone done this?
Burton produce some rather neat hydraulic slave cylinders that sit inside the bellhousing, but I'm not sure which boxes they can be used on. A
better alternative might be to get a hydraulic box off ebay (Mk 2 Cortina 1600e).
Dave
I have a hydraulic clutch bellhousing from a 1600E (with fork & pushrod) if it is any use to you, it does put the starter on the o/s though.
Nick
