I'm hoping to trial fit the Zetec tonight so will need to get the flywheel and clutch on.
Does anyone know what the flywheel to crank bolts on a Zetec blacktop should be torqued up to?
Stu
f-tight?
I knew someone would say that!
crossflow ones are 68nm-76nm
112 nm (83 lbft) according to Haynes
DEPENDS WHAT ENGINE YOU GOT 1.8 OR 2.0 LT THE 2LT IS 107NM AS I JUST DONE MINE
Mine is a 1.8 Blacktop.
I'll go for 83lb/ft.
Stu
