Ok looks like someone has nicked me engine number or i'm going blind...again!
Where is it suposed to be and if i ain't got one what can i do about it?
Image deleted by owner
[img][/img]
supposed to be at "B" looks ground off to me
I cleaned it up to see if there was a number there but alas nowt
So what can i do?
Originally posted by donut
I cleaned it up to see if there was a number there but alas nowt![]()
So what can i do?
But i will need an engine number though.
How do i get one or can i make it up
IIRC: I believe it may be possible to bring up the ground off number by applying a little acid to the area.
One of the clever lads on here with metallugical knowlege may be of help.
Memo to self; Got to stop watching CSI.
That is true, but I can't quite remember the technique. Basically, a light acid will eat the softer, non punched down metal away quicker than the
stamped bits, so they end up slightly raised. A lamp shone from the side will then help the numbers show up.
Or just go down the local scrappy and 'borrow' a new number.
Actually I thought the car had been in the road? Don't you have the V5 and thus engine number?
[deleted!]
[Edited on 12/10/07 by donut]
ROFL & what was you full name and address Andy - just for reference when the police check this forum for the court case...
shhhhhh
Quick question surrounding this - when I swap my Pinto to a Zetec - should I inform the DVLA?
Or keep quiet?
Is there a risk that with the change of engine they will want to inspect the car?
Stoo
I swapped the pinto for a zetec and just informed the DVLA of a new engine number and cc change, no probs there as engines are changed al the time.
Sweet thanks - one less thing to worry about.
Stoo
Hi guys, so what was the out come as to having no engine number stamped on the block ??
Jason
1, make one up and hope the SVA man don't care and DVLA accept it
2, Buy a block or get a knackered block of fleabay
3, use the number of another engine that's not going to be used on the road [not recommended for obvious reasons]
I was hoping for using the 'acid type' response
I'll have to re read 'I saw you', is says how to do in the book
Jason
Oh yeah, forgot about that one. I can't see it working to be honest but hey....
