As in the title, i'm after some photos of completed locost pinto engine bays to get an idea where people locate various components.
Photos from all angles would be appreciated.
I'm about to start the fit over the winter and would appreciate a head start rather than figuring it all out myself.
AL
Few in my gallery, link below. Cheers Rich
I've some in my photo archive if its a help
Feel free to browse my gallery too!
Mark
Pinto 45s
I will post some stuff soon. My main problem was working around the exhaust manifold, I am using one that exits below the chassis rail and takes up a
lot of space on that side. The next problem is the alternator, this was right in the way of the only route for the steering shaft so I put a micra
alternator on a new bracket to lift it out the way.
Choose your exhaust manifold early on and try not to commit to bits without checking first if you can avoid it! I also had to change the height of the
engine late on to get the gearbox height right and the engine level, that caused problems.
Good luck
Caber
A load in my gallery too
