anyone have Throttle Bodiy data for how many car engine bhp they can provide?
(specifically interested in Kawasaki ZX6R, and Suzuki GSZR 5750)
(I've read somewhere 600 TB can go up to 200 bhp and 1,00 go to 300 bhp !!)
You want to look at the injector flow rate and inlet size/how muchthey can flow. This will be far more acurate than someone coming up with a pub bhp
figure imho as it will depend on the engine and other tuning bits on it etc.
Ned.
thanks but no helpy, linky no worky
Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Inside Diameter: 38mm
Center-Center (left to right from behind): 75-75-75mm
Overall Length: 90mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Separate casting: No (dual Tbīs)
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
Originally posted by 02GF74
let's do quick sum.
most extreme mpg = 10 @ 60 mph so that is 6 gallons per hour or 450 cc per min.
If the above flow rate num ber is per injector, then there is plenty to spare.
Even at 20 mpg there is a little bit to spare assuming 245 is total flow rate.
tanks for that;
injector flow rate is: 246.09375 cc/min
so if the spec. above is per injector, then I am right on the button with these TBs.
