Hi , I am fitting a 1.8 Phase 1 Zetec to a Type 9 gearbox, will this combination work?
Engine 1.8 Zetec with spigot bearing fitted
Flywheel - 1.8 Zetec ( I also have one from the CVH Donor)
Starter Motor - From CVH Donor Lucas type
Clutch Cover - From CVH Donor??
Clutch Plate - from CVH Donor??
Release Bearing - from CVH Donor??
Gearbox - Type 9 from CVH Donor
I think I might need the release bearing from the Capri QH Part no CCT133.
Any advise welcome......... I'll be in the garage this afternoon to try out the above combination.
Keith.
i had 1.8 zetec clutch fitted ok
there are lots of info about this on this site
if you use the cvh flywheel and you using megajolt, you will need a trigger wheel i think to work vr senser
MInes on a 1.8 zetec mondeo clutch kit with the capri release bearing. Make sure its the earlier mondeo though as the plate and spigot is a different size.
Same set up here but with early mondeo 1.8 (220mm) clutch kit using an early capri release bearing quinten hazel part number for release bearing is cct133.
