Buying Dellorto Carbs- what to look for
James - 8/10/03 at 01:06 PM
I've been offered a pair of Dellorto DHLA 40 G (cast on left hand barrel) by a guy at work. Not sure how much he wants for them but as he made the mistake of telling me he was gonna throw them out I hope not too much!
I know nothing about carbs so was wondering if anybody could give me advice on what to look for before I part with any hard-earned!
He bought them about 10 years ago to put on a 2.0 Cortina but never got round to it. They'd been on something similar before so hopefully they're jetted for my purposes already!
They're on a manifold and have the throttle linkage mechanism. This activates all the butterflies so I guess this is a good start!
The idle adjustment screw mechanism is intact and the springs all seem to work fine.
The manifold has a 90° elbow screwed in the top of the left hand barrel and a brass bolt in the most right hand.
What the hell else do I look for!!!
Any idvice greatfully recieved!
Thanks,
James
barrie sharp - 8/10/03 at 02:02 PM
hi james i am lucky to live very close to a Dellorto specialist try www.dellorto.com. they are very helpfull in helping me get parts for my webbers and told me they are better than webbers ?
Phone No 01189431180
the place is called Eurocarb ltd.
DaveFJ - 8/10/03 at 02:27 PM
Hmm - how unusual - a delorto specialist telling you that delortos are better than webbers - pardon my scepticism..
In actual fact I have been told the same from another source....
theconrodkid - 8/10/03 at 03:53 PM
their worn out and useless james,give them here and ill bin them for ya
or check for play in throttle spindles and corrosion inside float chambers etc
James - 8/10/03 at 04:41 PM
If I knew what they actaully were then I might!
James
James - 10/10/03 at 05:09 PM
Hey, I know this is probably a really dumb question but if I don't ask...
These carbs don't have trumpets or air filters. Do I need both, ie. the filters fit over the trumpets or is it a case of one or the other? Both seems more likely!
Thanks,
James
theconrodkid - 10/10/03 at 06:07 PM
should be some tapped holes in the front face,jus bolt filter or trumpet on as desired
Peteff - 10/10/03 at 07:07 PM
The bellmouth goes inside the filter to smooth the flow into the venturi if you are desperate for every last bit of power. Otherwise just use a filter.
yours, Pete.
dblissett - 10/10/03 at 09:00 PM
hello james you want to check the butterflys are smooth also check the mixture screws still turn both size up and can be fixed at a cost also check the choke size as these are £15 ish each and you will need four if they are the wrong size for a 2ltr pinto you want 34mm or 36mm
it depends how much you have tuned it
other than that dellortoes are slightly beter but there is almost nothing in it
