I dont know if anyone can help but I have a zetec clutch friction plate - will this fit a 1.8 duratec as well as zetecs?
Thanks for anyy help you guys can give!
With a friction plate the only thing that really matters to the engine is the diameter. The type of central splines will depend on the gearbox you want to use. Sorry can't give you a yes/no answer but if the diameter is right and it fits your 'box input shaft it should be fine.
My issue is a strange one really - I have got a zetec motor / type 9 combo for my robin hood and the friction plate I got with the zetec clutch wont fit the type 9 input shaft (the type 9 shaft is much bigger) However I have a 1.8 duratec powered mondeo and am wondering how the mondeo gearbox input shaft compares to the escort gearbox input. Any ideas??
