It started with a head off and valve grind....Now sump off and pistons out!
Cranks and bearings look fine but I replace the shells while they're out...any recommendations about where to get them, or just fit standard
Ford ones.
bearings - raceline?
personally unless I was going for big power, I'd have replaced the whole unit. Surely would have been cheaper?
I got mine from Burton's as the Ford garage around here is like pulling teeth.
Standard are around £28
Alu/tin are around £70
[Edited on 4/1/08 by big_wasa]
