release bearing
theohighland - 7/1/08 at 06:51 PM
Hi, ive tried fitting the relese bearing and arm to my gearbox the other day, but struggled to get the release bearing in.
My question is, should the bearing slide al the way down the shaft of the gearbox, i.e over the sleeve part, or just sit loosly over the spline part?
Thanks for your help,
Theo
bonzoronnie - 7/1/08 at 06:59 PM
The release bearing normally sits on the sleved portion of the input shaft
Ronnie
theohighland - 7/1/08 at 07:03 PM
ok thanks, in that case, how many diffrent types of bearing are there, as the one i have doesnt seem to fit over the sleeved part?
or is it a really tight fit?
Theo
rusty nuts - 7/1/08 at 07:20 PM
Might help if we knew what gearbox you are using and possibly the part number of the bearing? The bearing should be an easy sliding fit over the sleeve . If it is tight you will have problems
theohighland - 7/1/08 at 07:23 PM
well its a type 9 (at least i hope it is, thats what i was told when i bough it on ebay and it looks like one)
i bought the bearing off someone using it in a type 9 in a cortina, so im wondering if there are different types of type 9 gearbox
Theo
Macbeast - 7/1/08 at 08:33 PM
To use a second-hand release bearing might be taking "Locost " too far.
I would buy a new one - they're not that expensive- and then you won't curse yourself as you take the gearbox off yet again
theohighland - 7/1/08 at 08:45 PM
where do i get a new release bearing for something that age?
Cheers, Theo
Macbeast - 7/1/08 at 09:11 PM
I got mine from my local Ford agent in Maidstone. It helps if you can quote a Registration No for the donor car or at least model/year.
I have seen posts about different drive shaft lengths and different no of splines so it is possible, I suppose, that there might be different shaft thicknesses.
Burton Power might be able to help too - www.burtonpower.com. Looking at their catalogue, they show 2 release bearings
HD3257 - bore 34.92, OD 66.0
HD3259 - bore 38.25, OD 68.5
I'm sure their sales people on 0208 518 9191 would be happy to advise.
theohighland - 7/1/08 at 11:20 PM
excellent, thnks very much, i'll look into that.
Theo
