Finally got the engine out of my BMW. The engine is an M40 1.6 litre out for a 1991 BMW 316. It is covered in mud though so a good clean needed and
then i will strip it down, paint and rebuild (hopefully with some preformance parts)
Been a good day
You'll find bugger all out there for the M40. Best off looking for a 1.8 M43, or find a 16v M42 or M44...
thanks but i would like to keep the engine so i will look around for some stuff. Im not going to go mad of the tuning
http://www.ppcmag.co.uk/forum/topic.asp?TOPIC_ID=4692
suggests a cam (and about 20Bhp) is available.
It looks like you get about 100Bhp as standard.
120Bhp then
Obviously it depends how heavy the engine is but 120Bhp in a Locost is going to be fun (even if a BEC engine would be half the weight!!!)...
i had a feeling i would get someone suggesting a BEC
But i would like to keep as it is obviuosly cheaper. i will take a look at those cams
thanks
alot
I've used one of those in an M40B18 (don't think it's actually available for the M40B16?).
It's a 278 profile cam which does make the engine a bit peaky unless you lighten the flywheel to get it revving faster. It'll also give
closer to 8-10bhp unless you go aftermarket ECU or have a new chip burnt for the stock ECU. Incidentally, piper claim 14bhp for the 278 Ultimate
profile, not 20...
Either way, at least you'll have plenty of engine upgrade options open for the future
Enjoy undoing the exhaust manifold from the head, ------------ the studs tend to break.
There's always Nitous!![]()
both very good points but i would like to keep costs down
anyone know what things are the same on the 1.8 and 1.6 m40 engine?
