Camshaft ID
Benzine - 2/2/08 at 08:57 PM
I need to find out what cam I have in my pinto as I'm selling it and I might have to update the ebay page if it's not what I've said it is (which I 'm now having doubts about) Obv I want to be as honest as possible etc
Stamped on the end is
214 K00 P20 and the symbol:
Thanks for any help
[Edited on 2/2/08 by Benzine]
Benzine - 3/2/08 at 05:15 PM
Anyone have any idea or know how I can find out?
MikeRJ - 3/2/08 at 07:05 PM
Measure lift and timing and compare against manufacturer specs of the cam you thought it was.
02GF74 - 3/2/08 at 07:25 PM
^^^ yep. not that hard to do.
I've done this with a rv8 cam. get piece of wood, nail two pairs of nails at 45 degrees to form a V to rest the bearing on - this is good enough stand. Then make a steel bracket for the dial guage and off you go!!
Not perfect but would show the lift and the timing to within a couple of degrees that maybe enough to identify it.
It is a good excerice as you get to see how precise the lobes are ground.
