hi can anybody tell me what these pipes are for there is a large one and a small one that come from the middle of each pair and also a very small
pipe that comes out the end of the set ..jpg)
Picture's too big and blurry marra.....
Top one vents the slides, bottom one vents the float bowls.
Other two underneath are the fuel supply
HI SORRY ABOUT THE PICTURE SIZE I DONT KNOW HOW TO MAKE IT SMALLER !
WHEN YOU SAY VENTS TO SLIDES AND VENT FOR BOWLS WHERE CAN I PUT THEM WITH NO AIRBOX JUST A FILTER
PLATE.jpg)
original pic smaller
Hi mate, the 2 ones between eachj pair of carbs can just be left open. the other one that is metal needs blanking off as its a vacuum. just place a bolt in the rubber pipe and put a cable tie round it.
