hay all me and my mate are superchargering his mg zs, it has the k v6, im after any information at all, like what can be kept, can i run the standard injection set up for now? the idea is to run a low pressure, possibly around the 9psi mark, cheers the snake
See here:
http://forums.xpowerforums.com/showthread.php?t=40682
Do a search on RSM as well
Simon
A ZS 180 ?Only pit fall I can see is the variable geometry inlet manifold, which is just about the only unreliable bit on the standard 2.5 engine.
