MT75 Hydraulic conversion
mgmiller - 6/3/08 at 08:12 PM
Hi
Has anyone done a hydraulic clutch conversion to a clutch cable MT75 gearbox. If so what is required and where can I buy the parts?
Also where can I get a quick shift for the box? I'm looking for a more positive feel to the gearstick.
Mark
r1_pete - 6/3/08 at 08:57 PM
I'm looking at ways of doing the same thing, favorite at the moment is a slave cylinder at the back of the clutch arm pushing forwards.
Quick Shift - bit dear for my money, I've shortened the lever - same effect.
To make the shift more precise do away with the rubber mountings on the shift cage, I've welded discs in the lower mounts and re workked the top mounts by welding corners into the cage and drilling them.
Pete.
[Edited on 6/3/08 by r1_pete]
Schrodinger - 6/3/08 at 09:04 PM
Do a search on fleabay you will find that there are a number hydraulic clutchs from different cars for sale.
mgmiller - 7/3/08 at 01:26 PM
How about using a CONCENTRIC CLUTCH SLAVE CYLINDER from a mondeo.
I think the input haft size is the same! or am I wrong?
