All - is there a spacer plate available to allow a V6 (long input shaft) type 9 box to be used on a 4 pot? Looking at the options before forking out on a custom box!
I've read that spacers are available, but can't find one anywhere. I think you need 25mm and this would be easiest between bellhousing and
gearbox.
I've also read you can just chop 25mm off the imput shaft with a grinder.
Something like this available from Caterham I believe.
Dusty those are my photo's..
and its a Caterham spacer that i got from this site second hand. The caterham spacer which is 30mm thick with a 10mm lip came with longer bolts and a
gasket.
Fits easily using the V6 box and the standard 4 pot bell housing.
You may need the longer Capri release bearing of a manual adjusting clutch cable to get the bite position correct.
If someone is good with CAD then it is a simple copy of the bell housing mounting face 30mm thick with locating lip and recess for gear selector.
thanks all - I might be being thick, but what does the rebate do? does it take in the front of the gearbox?- could I not open that shape up to full depth rather than just a rebate? - just thinking it might be easier to make....
ok- thanks for that, think the item in question is this
here
a bit steep for what it is, but if it saves me forking out for a custom box, then it might be good value (ish).
Shameless. With acknowledgement to snapper for the stolen photo's.
Morning Guys,
Bumping up this old thread, Do caterham still do a spacer like this? has anyone got one they would like to sell?
Or..
Has anyone a CAD drawing for the Ford Type 9 mounting face that they would be willing to share?
Even a .PDF or .JPG version that i can import into CAD to Pitch the input shaft & 4 locating holes against each other?
Many thanks!
Available from Burtons
i got one recently from retro ford
