hi all iv desided on the engine im using, i know that the c20let turbo pistons will fir onto the con rods of a 2l zetec engine, just wondered if the
c20xe pistons will fit the same?
many thanks
piggy
Originally posted by piggy1600cvh
hi all iv desided on the engine im using, i know that the c20let turbo pistons will fir onto the con rods of a 2l zetec engine, just wondered if the c20xe pistons will fit the same?
many thanks
piggy
I've heard of xe pistons being used in a zetec when making it a turbo. you have to bore the zetec block out to the xe piston size (86mm),
apparantly the deck height and compression ratio of the xe piston is near enough what you want to make a zetec turbo charged and a second hand set of
xe pistons is a cheapr route even with a rebore than purpose made zetec turbo pistons. Also makes the zetec 2.1ish iirc.
..all second hand info but a search will prob show more first hand info. Also search on zvh turbo, zetec block with cvh (rs turbo) head.
Ned.
I've heard of xe pistons being used in a zetec when making it a turbo. you have to bore the zetec block out to the xe piston size (86mm), apparantly the deck height and compression ratio of the xe piston is near enough what you want to make a zetec turbo charged and a second hand set of xe pistons is a cheapr route even with a rebore than purpose made zetec turbo pistons. Also makes the zetec 2.1ish iirc.
