Is there any jetting guide for the twin choke carbs or the single choke ones?
I know there are quite a few good ones for DCOE's, is there something similar for the twin choke for eg?
On another note, can someone explain to me how with the plunger type choke enriches the mixture? I cannot understand it even after looking at exploded
diagrams.
http://www.tigerownersclub.co.uk/download_files/JETTING.EXE
Thanks but that is for DCOE's I was after the single barrel or twin choke carb preferably.
My rather ancient Weber book (priced at 15 shillings!!!) gives the jets for a 1500 Ford Cortina GT as follows:-
Primary.
Aux Vent 4.5
Vent. 26
Emulsion F30
Main Jet 140
Air 230
Slow run 50
Slow run Air 200
Pump 50
Secondary
Aux Vent 4.5
Vent. 27
Emulsion F30
Main Jet 155
Air 180
Slow run 70
Slow run Air 70
Maybe this will help you ascertain if you are in the right ball park.
Drew
Thanks, Now I know I am running a little weak on the main fuel side. Could you please tell me which are the slow running air jets?
Here is an exploded view of my carb.
