manifold glowing red
graememk - 14/4/08 at 09:48 PM
does yours ?
could my ignition timing be out if so which way ?
Volvorsport - 14/4/08 at 09:49 PM
retarded
Hellfire - 14/4/08 at 09:55 PM
Originally posted by Volvorsport
retarded
He only asked a question - that's verbal abuse that is
graememk - 14/4/08 at 09:58 PM
retarded
just spat my beer out pmsl
Volvorsport - 14/4/08 at 10:01 PM
lol , KISS !
RazMan - 14/4/08 at 10:02 PM
When my car was on the rollers the collectors on each bank were glowing a bright red which was scary at the time
With normal road use I would be surprised if they could get that hot due to the extra airflow - turbos however are a different story.
Miks15 - 14/4/08 at 10:07 PM
saw this earlier an thought it fits in nicely with this post! plus it looks cool after about 40 seconds ull start to see what i mean!
Link
graememk - 14/4/08 at 10:09 PM
mine is turbo, is this normal or very bad
redscamp - 14/4/08 at 10:17 PM
bike exhuasts glow if its dark enough to see them (hot enough to blue chrome)
RazMan - 14/4/08 at 10:26 PM
Quite normal but usually after a good thrashing
graememk - 14/4/08 at 10:29 PM
on right oh dear i've never taken mine above 3000 rpm pmsl
Mr Whippy - 14/4/08 at 10:59 PM
red, mine tend to glow orange
Daimo_45 - 14/4/08 at 11:53 PM
Few of my mates have turbo tintops and they glow red when they're thrashed.
speedyxjs - 15/4/08 at 06:47 AM
Your avatar seems to glow red if that counts
Mr Whippy - 15/4/08 at 07:54 AM
I have plans....(queue the manic laugh )
tegwin - 15/4/08 at 10:05 AM
Thats a sign of a badly designed combustion chamber....
If you design the combustion chamber properly there is a flow of cooler air around the outside of the pipes diameter to keep the walls cool.... That turbo wont last long...not long atall!
britishtrident - 15/4/08 at 03:25 PM
Yep -- On a non-turbo engine it is generally a sign of ignition is too retarded the excess het is caused by the combustion being incomplete before the exhaust vavle opens as a result a higher percentage of combustion heat energy is rejected to the exhaust.
Turbos are a bit different and will get a buld up of heat after being thrashed which can cook the oil in the turbo bearing drastically shortening turbo life..
With a turbo you should :
(1) Always allow the turbo to cool down after a hard drive -- ideally drive quietly for half a mile or so and allow to idle for up to a minute before switch off.
(2) Use a top quality synthetic oil.
[Edited on 15/4/08 by britishtrident]
