I will be looking this week at a Ford Capri 2.0S, but how do I know that the engine is a 2 liter and not a 1.6?
Are there any reconizable differences between these two engines?
I think there is a '2L' cast in the side IIRC
I agree with Whippy mine has 2.0 cast on the side.
According to Mr Burton -
"....Cortina blocks usually have the capacity in small numbers on the side - 16 and 20 respectively. Later Sierra blocks have 165, 185 and 205
HTH
oh yeah that's right it's written as - 2.0 forgot
205 block is the one to go for !
If its a capri and original then it will be (or should be) the older type pinto, so it should have a blue cam cover and that should have 2.0 embossed at the bottom over the Idler/oil pump pulley.
weighsabout two ton and shaped like an anchor....I know
Ok, thanks!
That's exactly what I needed to know
