Are the engine mounts on the Zetec and CVH the same design, ie bolt pattern and size?
Cheers in advance,
Chris
no. L/H mount at least is different. Think the R/H mount may be interchangeable, though.
Above is correct BUT
1.8 RWD CVH mounts won't fit a FWD CVH or a Zetec as the FWD engines don't have the required bosses on the block casting.
[Edited on 24/4/08 by britishtrident]
The back one, if viewed in a FWD car, has the lowest of the three bolts in a different place. Some people bodge it with just two, but you should
really cut and shut the mount to move the hole to the right place.
Chris
