Making Alloy water rail for Zetec
Dave Bailey - 1/5/08 at 07:17 PM
Anyone know what wall thickness alloy tube can be used for making a water rail to reduce the hose required?
I have a focus 2.0 Engine...
thanks
Dave Bailey
big_wasa - 1/5/08 at 07:25 PM
The raceline rail is heavy cast .
If it was flexibaly atached to the stat housing I would make one out of 16swg tube same as my tubes from the rail to the rad.
procomp has a very nice setup, better than the water rail.
tim windmill - 2/5/08 at 07:20 AM
B+ Q ariel mast works a treat and nice and lite
timex - 2/5/08 at 01:07 PM
Just what im using (B&Q Aireal mast 32mm DIA) Just geting it welded up today. I will try and get some photos for you latter. Its just ideal and like said very light .
timex - 3/5/08 at 05:11 PM
Some pictures of how we have re plumbed ours if you click on Update 03/05/08
http://www.locostbuilders.co.uk/photos.php?action=gal&user=timex
Just need to get a few more hoses to connect the header tank and the thermostat bypas to the bottom Alloy pipe. Stoneleigh here we come
Then it the SVA
