Noise
The Baron - 12/5/08 at 05:35 PM
The final thing to correct from my SVA fail list is NOISE!!!!
I peaked at 102 db (before my engine blew up, oil pump failure followed by head gasket)
I have a non re-packable silencer from Robin Hood. I've inserted one of those baffle things from CBS, but I’m still not convinced it’s any quieter.
I was thinking about packing steel wool around the baffle, is there any other tricks I can do?
B
PAUL FISHER - 12/5/08 at 05:40 PM
A decibel killer will do the trick,it will knock off around 5 db's,they are very effective.
http://cgi.ebay.co.uk/MOTORCYCLE-EXHAUST-BAFFLE-KIT-NOISE-REDUCTION-db-KILLER_W0QQitemZ190220371177QQihZ009QQcategoryZ25623QQssPageNameZWDVWQQrdZ1QQcm dZViewItem
BenB - 12/5/08 at 06:02 PM
Use a tacho which over-reads
IE the noise test is done on indicated rpm not actual....
Kriss - 12/5/08 at 06:47 PM
great post and info. cheers for the ebay link.
think I will be utting on of these in my can for my R1 if it fits. Think Chris has got me a bike style carbon can, similar to the ebay piccy
5db, really???
The Baron - 12/5/08 at 07:05 PM
Thats what i fitted tonight, and i'm not that sure its made that much difference.
andyharding - 12/5/08 at 09:56 PM
They're not stupid. They check your tacho is accurate.
MkIndy7 - 12/5/08 at 11:20 PM
Limit the throttle pedal travel... wonder if they've thought of that one!
MikeRJ - 13/5/08 at 08:36 AM
They don't run it at WOT do they? They simply open the throttle to get the required RPM with no engine load, so the throttle will be at a very small opening anyway.
