Ok so here’s a stupid question…
There I have a couple of twin Webbers (40 DCOE 18) on the pinto and I’m suppose to balance them right, fair enough makes sense I’d want one carb to be
opening the same amount as the other one, but for each carb can I adjust the individual barrels relative to each other, don’t see how, thought there
might be an air bleed screw perhaps but don’t see one off those. No adjustment of the butterflies either, nope don’t see at all what I’m meant to be
fiddling with.
Am I wrong here?
Haven't got dcoe but have book marked this page for some reason, there is a picture on there that does say when the throttle adjustment screw is
etc.
LINKY
Rich
No you can`t balance each individual choke , you balance 1 choke on each carb to ensure both carbs are breathing the same. If that makes sense! you should be able to adjust the carbs with the linkage between them, then set them up with the idle mixture screws on each choke.
cheers for that guys
that setting up instructions are great, what a big help
[Edited on 20/5/08 by Mr Whippy]
think i may have a haynes manual for dcoe's
