presure regulator - how to set?
ditchlewis - 22/5/08 at 07:30 PM
I have a filterking pressure regulator, but i dont have the instructions. i have to set it for 3PSI how do you do it? Help!!!
anyone got a PDF of the instructions?
Ditch
tul214 - 22/5/08 at 08:13 PM
You turn the slotted screw on the top. Anti clockwise to slow the pressure but you need a guage to set it properly. I got one from the bay for a couple of quid.
http://cgi.ebay.co.uk/50mm-Pressure-Gauge-Base-Entry-0-15-PSI-AIR-AND-OIL_W0QQitemZ310051442960QQihZ021QQcategoryZ48718QQssPageNameZWDVWQ QrdZ1QQcmdZViewItem
[Edited on 22/5/08 by tul214]
David Jenkins - 22/5/08 at 08:36 PM
Ditch,
Does your regulator have a brass plug on the bit next to the outlet? If so, I have a pressure gauge that'll fit in there nicely.
If you don't have the brass plug you'll have to get a gauge that goes in the fuel line, or use a connector like this.
Give me a shout if you want me to drive over and help you to set your regulator (any excuse to get the car out!)
[Edited on 22/5/08 by David Jenkins]
ditchlewis - 22/5/08 at 09:06 PM
many thanks.
david my regulator looks like yours but with simple in and out pipes. i will have to get the piece like the link. i will give you a call when i get it and many thanks for your help.
i'm away this weekend so i may not get the pump installed, i'm just about to fit the air box i made.
many thanks ditch
mark chandler - 22/5/08 at 10:42 PM
I do not think you have to be that precise.
All you need is adjust so that fuel starts to leak by the float needles then back the screw off 1/4 to 1/2 a turn and monitor things for a while.
The last thing you want is insufficent pressure at full load !
