got my megasquirt from the states after your advise from diy auto tune,5 days later it arrived with no tax or import duty.Im part way through
soldering and at the first programming stage and stuck.I have downloaded the s19 file and loaded it,got megatune and the ini file but cant get it to
m/t and realtime does not work on the test.before i chuck my laptop can anyone advise,i will also list my no just incase. 07792166364. thanks.
ps, its a ms2 v3
hmmm, laptop...
are you using a proper old skool serial port, or one of the usb to serial converters? they have incompatability issues.
other than that, i don't know. sorry
If you are using a serial port, are you using the correct serial (RS232) lead?
It's a while since I did all this but IIRC it has to be a serial extension lead, other types, like null modem etc. won't work.
I had to put a reversal in my lead to connect.
As you have loaded the files its sounds like you have good comms anyway.
That aside I could not communicate with mine initially using the megatune package, then loaded megatunix and could now see the ECU.
Once I had proven with megatunix megatune started to work... This is not uncommon if you have a google.
yes must have coms as i managed to load the s19 file but i am using a usb adapter to my laptop.will look into the other tuning software you
mentioned.
The instructions get a bit complicated with needing this file and that file etc,better off they supplied a cd with updated online ..
The s19 file is the firmware which is normally preloaded on the processor .Are you sure you needed to load that file ?
Paul.
Originally posted by jonesier1
yes must have coms as i managed to load the s19 file but i am using a usb adapter to my laptop.will look into the other tuning software you mentioned.
yer,if the daughter board comes with a jumper installed then it needs s19 etc loaded.will give it a try on a pc at work with serial ports
tommorrow,failing that i may be looking for a budding megasquirt builder to take over
