Hi all,
Has been a while since I have posted due to my ever increasing kitcar fix which has resulted in me spend every hour of everyday searching the world
for parts!
I know this probably has been covered thousands of times!
I am currently looking into fitting bike carbs to my 1.6 zetec and was wondering which model of bike would be best to source this (i.e GSXR)?
Hi i have a pinto and i have zx9r carbs fitted but you could use r1 too if you do a search you will find lots of info about them
Jacko
Contact Bogg Bros. They will know.
ive got ZX6 carbs on my tuned 1600cvh which at 38mm would think would be fine on a 1600zetec also come fitted with a throttle position pot on the end for of the butterflys for any electronic ignition system, think may be some pictures in my archive
Here's my experience so far, using Honda CBR600 carbs and a home-made manifold.
Bike Carb link
Still an unfinished project as I'm currently sorting out the tuning. Once the weather improves I'll get back to it.
I can say even now that they are better than my old Weber DGV down-draft carb - tick-over is ultra-reliable and at a far lower rpm: unpredictable
1000+ rpm with the weber, rock-steady 750 rpm with the bike carbs. Also I no longer get a stink of petrol after stopping the engine (something to do
with the weber sitting on a hot manifold, I think).
[Edited on 29/5/08 by David Jenkins]
hi, i am have got a set of cbr600fx carbs and a home made manifold, like david.
i got a lot of my infomation of david's sight, it is very usefully.
i am have a 1.6 pinto running on cbr600 carbs.
there are some pics in my archive.
thanks
stuart
