Has anybody got the physical dimensions of the Ford Focus engine/trans?
Yes, that's the right idea.
BUT, the French buy french cars, Peugeot, Renault, Citroen, and I have never seen a french registered Focus!!
If you get specific about what dimensions you want I could have a measure on mine
Many thanks.
Just want to know the overall width for fitting in an old chassis I have in the shed, which is 26 inch wide.
Don't mind a little bit sticking out such as the clutch housing.
There is a dimensioned outline of, I think the Zetec SE here.
http://www.fordpowerproducts.com/FordPowerProducts/pdf/ZSG_Range_Leaflet_4_2003.pdf
There is a regular Zetec dimensioned drawing here.
http://www.locost7.info/files/engine/zetec1.jpg
Sorry haven't seen gearbox drawings anywhere.
My Focus 16V Zetec measures approximately:-
55 cm wide
60 cm long with gearbox projecting a further 30 cms
65 cms high
Hope this helps.
Many thanks
