What is the safe revs limit for a 1.8 silver top zetec?
I've hit 8000 a few times today and thought I might be pushing it a bit too hard.
I used to take my 2L to 7200 on a regular basis and did so for 6 years. Wouldnt go further than that without a set of ARP con rod bolts myself
Rev it till it goes bang and then back off a couple of hundred revs.......
I`ve been wondering what the `safe` maximum revs should be for my V6 - it pulls hard up to the self-imposed 7800 limit , but is that too high ?
Mmmmmm 8000 might be a bit too much
My rev limiter is set around 7200-7300. i was advised a few years ago that it will go to around 7500 happily but I don't much fancy risking it!!
Thanks I'll back off a bit and look at fitting a rev limiter.
Saw a Zetec failure at the Cadwell 750 meeting just gone. Suspected piston failure, rod then had a damn good go at cutting the engine in half. Very
messy. He said that he'd upped the limiter to 7700 from memory, which is the about where it went apparently.
[Edited on 4/6/08 by andylancaster3000]
Is it possible to programme your Megasquirt to limit revs?
Biggest danger over reving is the valves touch -- bent valves might to be be obvious at first the engine just looses its edge particularly when
pulling hard from low revs in a high gear.
[Edited on 5/6/08 by britishtrident]
