Type 9 gearbox to bellhousing bolts, removal?!
oldtimer - 18/6/08 at 05:25 PM
OK, so I may be being a bit dim, but, when removing the bellhousing from a type 9, 3 bold heads are exposed and one is under the clutch arm, how do I get to it??!!...........................
BearingKits - 18/6/08 at 05:33 PM
Knock out the peg and the clutch arm will come off.
rusty nuts - 18/6/08 at 06:29 PM
No need to knock out the peg just pull off the bearing and pull the arm towards the cable side of the bell housing
