As above. I notice that there are two hoses coming off the plastic tank I am going to use; one for the radiator, just under the cap, and the other
Where does the other hose go?
It is a serious question, I am asking because I really have no idea. Thanks.
top hose is vent to under the car bottom is expansion hose on mine see drawing
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=New%20Picture.JPG
yep mine too. One to the rad overflow and one venting down to the floor.
So it basically doesn't go anywhere, just to the outside?
If this is the case, it meets the criteria for the easiest thing I've done on the car so far!! Just have to find a way to attach the container;
should be easy to put it up by the rad.
on my setup, one to top of engine, one to top of rad.
Darren
contact deneo on here he'll make you a tank for £35 PLUS POST
I got one from my donor (one of the only things I used: the others were bolts, seat runners, and rear reflectors), and installed it today by making a
little ally bracket and zip ties. It'll do the job.
Thank you everyone!
