Is This As Easy As It Looks?
scootz - 15/7/08 at 03:19 PM
One of the OEM headers on the RS4 engine got squashed, so I cut the offending section out.
I'm not a welder, but to me it looks like a fairly straightforward repair... any opinions before I take it to 'a man'!
PIC HERE
nib1980 - 15/7/08 at 03:23 PM
looks simple, unless the system was plasma, or ceramic lined, then there would be a drop in performance, but only marginal.
Don't know Audi engines well enough
Mr Whippy - 15/7/08 at 03:24 PM
stainless?
Looks easy, I'd check the mating surface is flat after welding (lay a steel rule across it) chances are it will distort and need a light skim. I'd bolt it to the head and then weld it up, mind to plug up the ports first. Definitely best done with a TIG to limit distortion.
mr henderson - 15/7/08 at 03:58 PM
That's too big a gap to fill with weld. You really need a piece of tube in there
John
scootz - 15/7/08 at 04:09 PM
I do hope that was tongue in cheek John
mr henderson - 15/7/08 at 05:05 PM
Basically yes it was. Did you like my deadpan delivery?
John
scootz - 15/7/08 at 05:30 PM
It's the way you type 'em!
Mark G - 15/7/08 at 06:02 PM
Looks like an ideal location for a turbo if you ask me!
JohnN - 15/7/08 at 06:44 PM
The right hand end looks as though it may be a bit inaccessible for a tig weld?
Mark Allanson - 15/7/08 at 07:48 PM
With the flattened section removed, should be a simple job to reform it, weld it back in with rutile MMA if access if tight
