Type e bolts
Matysiak - 25/7/08 at 10:52 AM
New member from South Africa. I will be installing my crossflow this weekend to a ford type E gearbox. ASyone know what size bolts are needed to the gearbox and engine? Since i bought things seprately I don't have any bolts.
Mr Whippy - 25/7/08 at 10:58 AM
type E...? never heard of it
Matysiak - 25/7/08 at 11:03 AM
I think its a version of the "rocket box".
MikeRJ - 25/7/08 at 12:17 PM
The Type E is the one fitted to four speed Sierras, and the later 1.6 and 2.0 Capris and Cortinas. It's almost a direct replacement for the Type 9, except the mounting point and gear lever are a bit further forward.
Mr Whippy - 25/7/08 at 01:10 PM
oh right, then I have one in the garage!
rusty nuts - 25/7/08 at 05:45 PM
IIRC the two top bolts that screw into the cylinder block are 3/8" UNC. The type 9 bellhousing bolts ,the ones the go through the block and screw into are 10mm . The E type bellhousing could be either? HTH
