ugg!! it's still leaking....
02GF74 - 4/8/08 at 12:29 PM
Replaced both halfshaft bearings (English axle) as both were leaking oil, passenger side being much worse.
Now passenger side is dry but driver's side is dripping, not a lot but it should be dry too.
I ground off collar and bearing, heated bearing in oil - say not more than 100 temp and smacked it down with a square tube drift. Collar heated on BBQ, maybe 400 C max then again smacked down - collar much easier to fit.
Now the bearing outer has a groove in which sits an o-ring- it is quite hard to get that past the back plate and presumably into the axle without it popping off so I suspect it has popped off on driver's side.
If not - and I'll find out tonight - any ideas?
Only other place oil can come is via the seal. I don't think the heating damaged the seal; once collar was on I cooled it down with water.
Could the seal have been damaged by the hammering? The square tube for sure presses on the outer race but I am not sure it presses on the inner but then wouldn't the inner race be pressed down via the ball bearings, leaving seal intact?
clairetoo - 4/8/08 at 02:09 PM
My new bearings did'nt have the `o` ring grove so just put a smear of thread sealer on them - so far no leaks
britishtrident - 4/8/08 at 07:02 PM
Pul the shaft out,
For peace of mind check the bearing is the correct way round.
Clean everything up, if "O2 ring damaged toss it in the bin.
Put a smear of Loctite Lock n Seal in the recess and round the outside of the bearing and refit.
Check the axle breather is clear and the axle isn't over filled --- nb axle should be level in both axis when checking.
[Edited on 4/8/08 by britishtrident]
02GF74 - 5/8/08 at 08:28 AM
It was the O-ring.
The bearings are the correct way round - I had trebble checked when fitting .... )and almost forgot to fit the flange.. )
Will make one more attempt with an O-ring.
Will clamp it with jubillee clip overnight to squeeze it down. If that fails, tnen it is sealant time.
02GF74 - 6/8/08 at 01:30 PM
.... well new o-ring fitted and clamped down with a jubillee clip for 2 hours - that seemed to make it easier to go in.
this time I spent a lot time checking with a torch to ensure the ring was going in properly.
will know in a day or two if the operation waqs successful, fingers crossed......
I did learn one thing; you cannot top up the diff via the half shaft tube - the point where is joins the diff housing is of smaller diameter so the oil will not flow into the housing hopefully I didn't lose that much oil.....
