Has anyone fitted one of these? or the n/a derivative from the 850?
Im just wondering how much of a mare the wiring will be, and how much I need to keep by way of the clockset, abs ecu etc.....
cheers
Yep, just done it myself. Don't need anything except the engine loom and all sensors/actuators and the ECU. No need for clocks, ignition barrel
etc as there is no imobiliser in the ECU.
I've got a feeling my ECU is restricting boost due to a lack of road-speed sensor input, but if that is the problem I'll get round it with a
signal generator of some sort.
Edit: Mine's a '94 I think, but I don't think thay changed anything from 94-95.
[Edited on 12/8/08 by matt_claydon]
happy days!
bloke I know is doing an aui v8 transplant and needs the igition barell and key, clockset, ecu, seperate immob ecu and even at that half the wiring
will need replaced to avoid having to use the original fusebox!
so with the T5 you have the engine loom to the ecu, and then what? live, neutral, rev counter feed, ignition live, fuel pump feed and not much
else?
cheers
The engine loom has two white connectors and a black one. The white ones go into the ECU and the black one has 'vehicle loom' connections
like ignition live, reverse light, and some others I can't remember. There are other outputs like rev counter etc but I've just connected my
rev counter to the coil as the signal from the ecu is Volvo specific.
The volvo ecu fuel pump output is a special signal, so you either need the fuel pump 'relay' from the donor, or do your own fuel pump
control. For safety it's best to use the Volvo relay so that the pump stops if the engine does.
I have the complete pin-out and wiring diagram for the engine loom/ecu which I'll attach below. THe black connector is not shown, but the wires
are there. You can work out what's what from the wire colours.
Pin allocation:
excellent. PDFs arent playing ball at work so I will have a look later on.
wiring sounds simple enough tho, Ive done vauxhall xe's etc before and this sounds remarkably similar!
cheers Matt
Junk the wiring and go bike carbs and Megajolt.
With a turbo? I'd like to see the plumbing for that
(Yes, I know it can be done, but what's the point when you can have the best part of 300bhp and great driveability and fuel economy on the
standard TB and ECU?)
I'm trying to work out my starter/solenoid wiring at the mo on my volvo engine
I've got the earth sorted. There are 2 terminals on the starter, not sure which to use
test for electrical continuity between them, you might find one is meant to go to the battery and one to the alternator and both are in fact +ve.
ok so youve done that.....
at this piint I would probably start shorting things out with a screw driver to see what worked (briefly) so Im gonna shut up before I get you killed
lol
Two in addition to the fat screw for the battery live? If so I'd just try shorting them both to the live terminal and see which makes the starter engage.
No 3 is a spade connector
2 goes straight to battery positive terminal using a big fat wire. 3 goes to the sprung 'start' position on the ignition switch.
When you apply 12v to terminal 3 the solenoid activates, throwing the pinion gear forward and connecting 2 and 1 together to make the motor spin.
Should be exactly the same as your old Pinto.
soo, bin nice factory efi that passed all emissions regs and makes 225bhp and replace it with some nasty carbs? Ill pass thanks!
Nasty carbs?? not as nasty as EFI! It is the easy option for just as much power.
In your photo you do not seem to have a nut on No1 if the wire already on that is not making a good contact then the solonoid (sp) will not make contact to the starter. Put a nut and spring washer on and tighten it, then 2 to batt+ and 3 to ign start poss. on ign. sw. If that doesn't work then your solonoid is stuffed. Cheers Ray
2 - big fat wire to battery +ve - check
The only way I seem to get any life is having another red wire (thick but not as thick as battery) so terminal 2 and a blue/black thin wire to terminal 1. That makes the starter spin but not engage.
properly setup ITBs will always beat individual choke carbs if both are tuned with the same in mind (power, economy, whatever)
a single Tb EFI system will always hammer a large single carb into the ground too.
Bike carbs are a cheap route to almost Tb like performance if you bin efi I agree, but then MS and bike Tb's is better still.
Oh, by the way, what is all that based on?
Carbs and TBs will generally get the same peak power. It what lies between idle and peak that differs.
Carbs have (usually) three jets that try to cope with all load situations. EFI (with a 12*12 fuel map) effectively has 144 jets, each one for a
slightly different load and speed condition. EFI also has the ability to modify the fuelling based on engine temperature, air temperature, etc. It
stands to reason it will give you a more optimal state of tune (but not more power, that is solely dependent on how much air you can get into the
engine, which carbs and TBs do equally well).
Why on earth anyone would ditch a modern turbocharged EFI setup for a set of N/A bike carbs I will never understand!
Are said above, carbs are to EFI what a dizzy is to mappable ignition. Old tech but cheap and easy to set up for those that don't want to
'tune by laptop'.
exactly, you can get closer to optimum fuelling in all conditions with mappable, which means more area under your power curve, and better economy on
part load.
Id use bike carbs,but only for a budget project where I didnt have the funds for proper Tbs and management.
if this engine is running , why dont we have video matt ?
oh and ive found me engine wiring diagrams for the 4 cylinder redblock 5 and 6 cylinder whiteblock .
need an email address to to post it to .
