please.
As per my previous probs with my plumbing has anyone got a pic of their pinto plumming with no heater?
check out my build log as it has a lot of pics. It you want a close up of something, let me know and I'll take one tonight went I get back home
and post it for you.
regards
TimR
//timr.spaces.live.com
Here's an old pic of a Robin Hood I had. You can see the output from the manifold goes through the carb's autochoke, then, where it would
have gone through the heater, it simply loops round back to the pump.
HTH
Blimey. Both look much more complicated than mine. Cheer chaps.
Any more?
Its straight forward if you have side draughts with the heater port blocked off. More complex if you dont.
Simple one:
Water pump to bottom rad
Thermostat to top rad
Small pipe on water pump to expansion tank
Small pipe on stat to breather on expansion tank and rad.
Blank off heater take off on inlet manifold, you dont need it.
Thats all there is too it
dose this help at all?
Flak Monkey, the only differences to my set up from your proposal is that i dont have anything going to the top of the Polo rad'. Im running bike
carbs so nothing going to them.
Mat, the tank is between the rad and the front of the engine. Someone else ive asked today suggests that i have too much serge into the tank because
of its position and the length of the pipes, or lack it as the case may be.
