Propshaft
triumphdave - 19/8/08 at 12:04 PM
Should there be locking nuts,locking washers or tabs or something on the propshaft flange bolts?Mine were loose
tegwin - 19/8/08 at 12:06 PM
If your bolts go straight into the flange then use locktight and a split washer...
If your bolt goes through the flange use locktight and a nylock on the other side....With some washers of course!
David Jenkins - 19/8/08 at 12:08 PM
Originally mine had bolts with a special coating (from Ford). Looks like blue paint when you undo them.
I used a Loctite locking compound when I replaced the bolts (the sort of compound that can be undone with a bit of effort).
Dingz - 19/8/08 at 12:57 PM
Ford still sell the proper bolts for the sierra, they are about £1.30 each I could look fot the pt. no. if you need it.
[Edited on 19/8/08 by Dingz]
RickRick - 19/8/08 at 02:28 PM
hmm loctite damages most plastics, i think that applies to nylon used in nlyloc nuts too, so using both together might be counter productive
triumphdave - 19/8/08 at 03:52 PM
Thanks but mines a cortina based.
I will try loctite stud lock.
Cheers guys
NS Dev - 19/8/08 at 06:08 PM
yea just use loctite
David Jenkins - 19/8/08 at 06:11 PM
And tighten them properly - they're usually at a fairly high torque setting, which can be hard to achieve on something that's designed to rotate!
hellier0437 - 20/8/08 at 09:20 PM
does anyone know what the thread is for the bolts that go into the flange?
thanks
