Morning All
I hear the BBQ was a hit. Anyway I am currently attempting to fit a radiator into my Indy R with a R1 engine.
I followed the build of Hellfire and purchased a Micra rad from the scrapyard however I can't seem to get it to fit (probably due to the inboard
shocks... Doh!).
Anyone got a suggestion? Anyone got a Rad that will fit they don't want?
Rob
I fitted a bike engine rad (R6) with some brackets that MK made up
Pic
BTW, Paul isn't tiny as the pic would suggest - he had MK build his chassis double sized.
Im not using the R chassis but my R1 is using a Polo rad if it helps
Cheers Fellas
Paul Where from and how much?
I think the space available on the R chassis is smaller due to the shocks, so not sure a polo will fit (same issue as the micra????)
Rob
R1 rad and fans with my ZX10R engine
I guess I am best with a bike rad. Do I need to go for a rad from a bike with a simular engine size/ are there other things to look for? Should I just
stick with either the R6 or R1 rad? Should I use the R6/ R1 fan or will the Micra fan do?
Thanks again.......
I have no experience of fitting the polo/micra rad but I am sure Paul Fisher has one so it may be worth a U2U
I got my rad from Malc at Yorkshire engines. Give him a call as I needed some plumbing advice as the R6 rad is different to the ZX10R plumbing
Paul
I'm using the rad that MK supply with my R1 - mkII escort I was told (by Baz at MK)
If you do a search for R1 plumbing, you should find the same diagram I used. I had a copy of it, but it's on my old computer.
I shall get on it thanks for the info.
Any particular age/ engine size Polo rad?
No pics of it with the nose cone on (they're on the camera still and the mrs has nicked it for the day), but you get the idea
Yep get the picture! They are spot on.
